Desmond_Lau
Jun 07, 2017Star
Orbi Router - QOS Setup
When I go to QOS setting, only see "Speedtest - powered by OOKxx", When I click the speedtest button, it will take a long time to run. After that, I go to Satellite to check "Connected Device", the ...
BravoRomeo
Aug 01, 2017Initiate
I was able to Apply change on that /QOS_dynamic.htm page by very carefully hovering the mouse on the bottom edge of the Apply button. It seems the page is unfinished and untested. Nevertheless, after hitting Apply I received a dialog about sending my MAC address to "the provider", then had to check the Dynamic QOS box again and hit Apply a seccond time. It stuck. No idea if it actually works. I'm about ready to use Orbi as an access point and move to Mikrotik for more capable routing.
Mestegall
Aug 01, 2017Star
While I was finally able to click "apply" thanks to your advice - I'm still not able to see where/how we can set the priority of how devices are connected to the internet. I have a wireless CPI camera (security) and often it keeps 'dropping' the wifi signal. There seems to be no rhyme or reason as to when this happens. I'd like to make it a higher priority to see if that will fix the problem.
Any ideas?
