Desmond_Lau
Jun 07, 2017Star
Orbi Router - QOS Setup
When I go to QOS setting, only see "Speedtest - powered by OOKxx", When I click the speedtest button, it will take a long time to run. After that, I go to Satellite to check "Connected Device", the ...
SKK
Dec 14, 2017Guide
When will Netgear officially support QOS on Orbi ? I have the exact same issue and get occasional disconnects on my main PC and ipphone and want to prioritize them.
sdyarnell
Dec 30, 2017Guide
I also have this issue. I have 2 IP cameras that consistently stop working with the Orbi, but they keep their IP. I am trying to add some QoS prioritization to these cameras in hopes that it maybe makes a difference. With this page being basically blank, I cannot do this.
- Boomerang3Dec 30, 2017Apprentice
Your issue sounds like signal quality / strength?
- sdyarnellDec 30, 2017Guide
It is not. I have 45db in both rooms due to the sattelite.
Yep, hmmm. I've got both old and new Foscams hooked up, no issues. Course each camera is different. So you think its the Orbi dropping the signal or communication?
