Desmond_Lau
Jun 07, 2017Star
Orbi Router - QOS Setup
When I go to QOS setting, only see "Speedtest - powered by OOKxx", When I click the speedtest button, it will take a long time to run. After that, I go to Satellite to check "Connected Device", the ...
shwnwllms
Jun 07, 2017Tutor
QoS is disabled when Orbi is set to AP mode:
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Do you have Orbi set up as a Router or in AP mode? If you have it set to AP mode the speedtest is all that will show up under QoS as everything else is disabled.
rbk50
Jan 28, 2018Tutor
When will Netgear fix this?
Seems a persistent problem even in router mode, I only have access to do a speed test on the QoS page, nothing more.
