shark2
Jan 27, 2020Aspirant
Orbi Router - Verizon Fios TV and wireless set top boxes
I am a Verizon Fios customer and use Fios internet and TV. I currently have a Fios WiFi router for internet. For TV, I have a main Fios TV One box that is connected to a coaxial cable, and then i have...
Jan 27, 2020Guru - Experienced User
Are you using the quantum gateway? They are very specific for streaming and a PITA.
You don't have to shut off the wifi on the verizon box. Just make sure you use a different wifi channel than what orbi is using.
that'd allow the verizon set top boxes to use the verizon router. That might be the easiest/fastest fix the for the set top boxes.
