Swiedeback
Apr 03, 2019Aspirant
Orbi router & satellite (RBK50) plus nighthawk X8 plus nighthawk extender ac1900
Good morning all- I’m currently using an orbi RBK50 system. The base station is in my office (upstairs), and the satellite is also upstairs in our game room. I have a PS4 and a few other devices wi...
Apr 03, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
I believe the R series routers only support Router/AP/Wireless Bridge mode. They don't repeat or extend wifi.
You might benefit by using the R series router as a 2ndary wired AP to the Orbi and off load some non essential or non managed very often devices on to the AP.
- SwiedebackApr 03, 2019AspirantI’ll have to check the additional details later tonight. I’m a few hours away from home right now.
I do know that the modem is the one that spectrum supplies with the gig internet package. I have a fully capable netgear docsis 3.0 (maybe even 3.1) modem, but for some reason they haven’t cleared it for their service (other providers that offer gig service allow that modem).
And the base and the satellite (both upstairs) are Around 25-30 feet away from one another. I could move the satellite unit farther away from the base unit, and maybe get the distance up to around 40 feet. That would require a bunch of cables running back to the entertainment center, but I’ve got enough of them to do it.
I’ve noticed that the connected devices downstairs sometimes drop out with my current configuration.
I could always just get another satellite unit for the orbi, but I’d really like to put the nighthawk router and possibly even the extender to use.
Would it be better to simply sell the nighthawk and extender, and use that cash for another orbi satellite unit? Thinking that may be easier.
Also, is there a way to use some of the older routers as access points? I’ll have to get the model #’s for those also, but it would be nice to use them to hard wire things in different parts of the main level.
Thanks for the quick response. I’ll post the model numbers and firmware later tonight when I’m home.- SW_Apr 03, 2019Prodigy
Have you tried setting up the old Router in "Bridge" mode to the main Orbi router?
The old Router has better WiFi HW and range than typical WiFi devices. Bridge mode will enable all your devices to have wire connection to the old Router, i.e. my poor man Satellite. You can try to place the old Router at the current Satellite location and see if you get the same performance. If yes, then move the Satellite downstairs. Otherwise, put the old Router downstairs if that yields better performance. Good luck!
...just to add to my previous notes.
The best benefit of using old Router in Bridge mode (other than saving money) in Orbi setup is that we will get Daisy-Chain for free, which is much better than any range extender setup. Depending on the HW, you might only get 1/2 WiFi BW with range extender.
