Jarredd
Jun 17, 2019Aspirant
Orbi Router Able to access cPanel for 1 of my website, but not the other
Hello! I have a couple of websites being hosted through inmotionhosting.com and have WordPress installed on them. On one website I can access the cPanel just fine through the backend. The other web...
- Jun 23, 2019
I just noticed the modem you are using is a 4G LTE Modem. The default setting for this is router mode so unless you set the Orbi into AP mode you will have double NAT and the root of your problem. You can confirm this by connecting your PC directly to the modem (unplugging the Orbi).
Log into the modem and set it for Bridge Mode.
Jun 18, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
- JarreddJun 21, 2019Aspirant
Hello!
Thank you so much. My Orbi system is setup in router mode with one satellite.
As stated in my original post for my Orbi setup,Router: RBR50 Orbi AC3000
Router Firmware Version: V2.3.1.60
The modem being used is also a Netgear. Model: LB1120
I want to confirm that this all works with other domains I own, it's just a problem with this one.I found out tonight that I can also not load webmail. I receive the same sort of errors, even on other ports. I'm not sure if there is an issue with the router and the specific server, but this is a recent problem. It doesn't make any sense that there is a problem with just the one domain. Ugh!
- Talk2MikeJun 22, 2019Apprentice
What DNS servers are you using? If set to an ISP's servers I suggest you log into your Orbi and change it to another server, such as Google Public DNS (8.8.8.8 and 8.8.4.4), OpenDNS (208.67.222.222 and 208.67.220.220), Cloudflare (1.1.1.1 and 1.0.0.1), etc.
- JarreddJun 22, 2019Aspirant
I was using the ISP's servers. I just changed to one of Google's, one of OpenDNS's, and one of Cloudflare's.
I also used both DNS server addresses for each without mixing.
It is still not working. I can still only access cPanel from a specific address and the webmail in cPanel doesn't function; I receive the same error that the server is not responding.
This is totally baffling me, it makes no sense as to why it's only effecting one domain yet it's nothing on the host/domain's side.
