clindsey14's avatar
clindsey14
Follower
Oct 09, 2017
Orbi Router adn TimeMachine Backup
I saw some previous posts where others had problems with Apple TV staying connected through Orbi but never saw any resolutions.  I can connect but can't stream.  I ran a network test and Apple TV said that it couldn't connect to Apple.  So, I restarted Apple TV and re-ran the download test.  It worked.  I went to go stream a movie and it ran for about 30 seconds and then dropped connection.  I restarted....wash, rinse, repeat.
Is there a fix for this issue?
1 Reply
  • Are you running the Orib as an AP or router? Is your ISP modem Bridged?
