Orbiuser1234
Sep 24, 2024Aspirant
Orbi router and satelite issues RBR50v2
Orbi router RBR50v2/Orbi satelite rb550v2 Hi. Not long time ago I started to have problems with my network setup at home. It was working just fine when I moved in to new apartment 1 year ago. I w...
- Sep 24, 2024
Might update FW on the RBS first then RBR lastly...
Sep 24, 2024Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
Orbiuser1234
Hi. I belive that Im using the newest firmware on my router and satelite. Yes,I am using auto channel on 2.4ghz. I tried to use diffrent channels on 5Ghz and it worked good for a while with good speeds but i went back to normal again. So far I didn’t try channel 48 on 5ghz. Size of my apartment is 80 square meters. Router is about 12-14 meters far from satelite. I will try your suggestions when i get free time this week and let you know
