Orbiuser1234
Sep 24, 2024Aspirant
Orbi router and satelite issues RBR50v2
Orbi router RBR50v2/Orbi satelite rb550v2 Hi. Not long time ago I started to have problems with my network setup at home. It was working just fine when I moved in to new apartment 1 year ago. I w...
- Sep 24, 2024
Might update FW on the RBS first then RBR lastly...
Orbiuser1234
Hi. I belive that Im using the newest firmware on my router and satelite. Yes,I am using auto channel on 2.4ghz. I tried to use diffrent channels on 5Ghz and it worked good for a while with good speeds but i went back to normal again. So far I didn’t try channel 48 on 5ghz. Size of my apartment is 80 square meters. Router is about 12-14 meters far from satelite. I will try your suggestions when i get free time this week and let you know
Sep 24, 2024Guru - Experienced User
Is there a version number of the FW?
- Orbiuser1234Sep 24, 2024AspirantV2.7.4.24
- FURRYe38Sep 24, 2024Guru - Experienced User
- Orbiuser1234Sep 25, 2024AspirantI did it yesterday. Give me few days to see if it helps
