TC10
Feb 10, 2018Tutor
Orbi Router and Satellite Firmware
Does the Orbi Router normally push firmware updates to the Orbi Satellite or do we need to manually upgrade the Satellite? If it does, will the Router upgrade the Satellite first or after the Ro...
DarrenM
Feb 12, 2018Sr. NETGEAR Moderator
If you are doing a manual update you will want to update the satellite first as the router does not push the upgrade to the unit when you manual update the router. Auto updates will update the whole system.
DarrenM
