Sfoss0209's avatar
Sfoss0209
Follower
Apr 27, 2017
Orbi router and satellite
I need to know the main difference between the orbi router and satellite. I was interested and under the impression the router can be used as an add on... Example I buy two pack and need to expand what exactly do I need to buy
  • Your Orbi system can have one Orbi router, and zero or more Orbi satellites. To expand you buy additional satellites.
1 Reply
