Flashpix
Jul 15, 2017Follower
Orbi router and satellites be painted to match
Can the Orbi router and satelites be painted with spray paint to match other decor items? Non-metllic paint?
Will this have any effect on range or transmission performance?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Flashpix
Doing this could void the warranty and is not suggested. It could cause heat issues or like you said possible signal issues.
DarrenM
