Flashpix's avatar
Flashpix
Follower
Jul 15, 2017
Orbi router and satellites be painted to match
Can the Orbi router and satelites be painted with spray paint to match other decor items? Non-metllic paint?
Will this have any effect on range or transmission performance?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Flashpix
    Doing this could void the warranty and is not suggested. It could cause heat issues or like you said possible signal issues.
    DarrenM
