JohnH74
Mar 24, 2018Aspirant
Orbi Router and WiFi Channels
my Sonos is not working and they have told me to change the Orbi channel as it is to congested. I cannot find an option to do this in the app. any pointers? thanks John
- Mar 24, 2018
I would set the router to 11 and the Sonos to 1. Farthest part. 5 is a sub channel that is not a primary channel.
thombe
Mar 26, 2018Apprentice
Another idea : Move to Wifi setup and specify your Orbi channel.
I actually had similar issues, and ended up moving sonos to Wifi and not the sonos mesh.
I personally found way better results. Each to their own of course, but I ditched the Sonos Boost that I had purchased in an attempt to resolve disconnect issues.
I have about 7 sonos items, now all running over the wifi rather than using the sonos mesh.
Oh I also recommend a wifi scanner/tool on your phone, to see what wifi networks are around and what channels they are on, so that you can set your orbi to a free channel.
(i use Wifi Commander or Wifi Tool on my wp10 but am sure there are others for other os phones)
Worked for me, no conflict with either neighbours or sonos.
Just a thought. Good luck.
