Spud204
Nov 14, 2019Aspirant
Orbi router assigning IPs on 2 different subnets
My Orbi setup consists of the RBR50 with one RBS50 satellite. My modem is bridged. The problem I'm having is the router is assigning IPs from two different subnets; 192.168.1.XX and 192.168.88.XX. ...
Spud204
Thanks for your quick reply.
The modem is a Hitron CGNM-2250. It has been bridged with wifi turned off.
I'm seeing the devices with the .88 IPs on the Attached Devices page. The type of device includes iPhones, iPads, Alexa speakers, Windows laptop and the Orbi satellite itself. The list of devices will change each time I reboot the router. At one point, the laptop I was using to troubleshoot with got assigned an .88 IP and I could not get access to the router admin page.
I can't confirm right now but I am almost certain none of the devices have any static IPs set on themselves. I think the changing list of devices with .88 suggests that as well.
Nov 14, 2019Guru - Experienced User
Can you confirm that the modem is still in bridge mode and hasn't been configred back to gateway? Seen it were ISPs push FW updates which can cause the configuration to revert back to gateway mode. This would be one possible cause.
If the modem is in bridge mode fully, here what I would try.
Turn OFF ALL devices, Including the RBS. Connect 1 wired PC to the RBR and factory reset the RBR. Press the back button for 15 seconds then let go. Once the RBR is ready, walk thru the setup wizard and complete the setup. I would set up the SSID name however don't input your PW that your currently using. Use a different PW for now. You'll change this later.
After getting the RBR set up, go in and change the default IP address pool size to the following, 192.168.1.100 to .200. Under Advanced/Settings/LAN Setup. I presume you don't have 100 devices online currently. :smileywink: Save and apply the change. The RBR will reboot. Once back to ready. Go back to the same place and add your PC as a reserved IP address. Save and apply. The RBR will reboot once more.
Change the PW for the wifi to what you normally use. Save and apply
After the RBR is ready, turn ON the RBS and let it connect. Do the same thing with the RBS and set a IP address reservation here. Save and apply. I would then connect one wired device, or wireless and let it connect. Do another reservation for this device. Graduate adding one device at a time and set a IP address reservation.
It's possible that you may run into a device that could be causing this .88 address to appear by using this process. The 88 IP address isn't coming from the Orbi.
Let us know if this helps any.
- Spud204Nov 14, 2019Aspirant
Thanks for suggestions. I will confirm the modem is still bridged and follow the process you outlined. I had assumed if a device was getting an IP from somewhere else, it wouldn't show on the Attached Devices list.
I will report back on how things turned out.
- FURRYe38Nov 14, 2019Guru - Experienced User
Seen strange things and others have reported similar odd IPs showing in the conntected device list on Orbi that originates from else where.
Hope this will find where its coming from.
