roneill18901
Apr 08, 2020Aspirant
ORBI Router automatically switching back and forth between 2 MAC Addresses
Why does the Orbi router swith back and forth between MAC Addresses? These dates and time seem to co-incide with a drop in Internet access. Lastest Firm: as of 4/4/2020 Orbi Router and 3 sateli...
Apr 08, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Are the RBS wireless or wire connected to the RBR?
Please try a factory reset and setup from scratch with the RBR and RBS.
https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1820500/highlight/true#M74929
- Retired_MemberApr 08, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Are the RBS wireless or wire connected to the RBR?What is the size of your home? Sq Ft?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Please try a factory reset and setup from scratch with the RBR and RBS.
https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1820500/highlight/true#M74929:smileysad:
- roneill18901Apr 11, 2020Aspirant
You really have not address the issue. You asked me to basically turn off a lot of things, and try a bunch of stuff. Apparently you do not understand the fundementals and have me systematically attack this problem.
