roneill18901
Apr 08, 2020Aspirant
ORBI Router automatically switching back and forth between 2 MAC Addresses
Why does the Orbi router swith back and forth between MAC Addresses? These dates and time seem to co-incide with a drop in Internet access. Lastest Firm: as of 4/4/2020 Orbi Router and 3 sateli...
Apr 08, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Are the RBS wireless or wire connected to the RBR?
Please try a factory reset and setup from scratch with the RBR and RBS.
https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1820500/highlight/true#M74929
Retired_Member
Apr 08, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
:smileysad:
