roneill18901
Apr 08, 2020Aspirant
ORBI Router automatically switching back and forth between 2 MAC Addresses
Why does the Orbi router swith back and forth between MAC Addresses? These dates and time seem to co-incide with a drop in Internet access. Lastest Firm: as of 4/4/2020 Orbi Router and 3 sateli...
Apr 08, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Are the RBS wireless or wire connected to the RBR?
Please try a factory reset and setup from scratch with the RBR and RBS.
https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1820500/highlight/true#M74929
roneill18901
Apr 11, 2020Aspirant
You really have not address the issue. You asked me to basically turn off a lot of things, and try a bunch of stuff. Apparently you do not understand the fundementals and have me systematically attack this problem.
