silvinnio
Feb 09, 2020Aspirant
Orbi router cannot be found after factory reset
Few days ago I have upgraded my ORbi RBK sistem to the latest firmware. The system worked OK but in the device list was only 2 devices from 10. After that I have done factory reset of the router and...
- Feb 09, 2020
Maybe I did not explain myself more clear as english is not my first language but the problem was that after firmware upgrade and after factory reset, the router RBR50 was not accesible anymore by any way.
I was asking if there were any way to access the router like safe recovery mode or something like that and... I founded here :smileyhappy:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
very easy... and now... working :smileyhappy:
Thank you for your time
michaelkenward
Feb 09, 2020Guru - Experienced User
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
silvinnio wrote:
I have tried also manual IP 192.168.1.10 on the PC and still nothing.
Where did 192.168.1.10 come from? Do you mean 192.168.1.1?
After playing around with things, be sure to restart your network in this sequence:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
- silvinnioFeb 09, 2020AspirantI am using orbi router rbk50 as modem with PPoE connection. When router is on there is no wifi network broadcast. Also if I connect by wire with my PC, it is not getting automatic IP so I have to setup manual IP as 192.168.1.10 on PC ethernet connection and router IP should be as 192.168.1.1.
Still no connection.
Already done all as suggested.
Is there any way to force IP or to change the firmware? I know that can be used telnet connection but only if there is telnet activated.- michaelkenwardFeb 09, 2020Guru - Experienced User
silvinnio wrote:
I am using orbi router rbk50 as modem with PPoE connection.The RBK50 is a router/satellite (RBR50/RBS50) combination.
It has to get the Internet from something. A modem, optical termination, something else.
What have you got plugged into the yellow (Internet) port on the RBR50?
- silvinnioFeb 09, 2020AspirantThe internet is coming from fiber optic media converter to WAN yellow plug but the problem is not related to the internet connection. The RBR50 cannot be seen, no any wifi or wired connection. The orbilogin.net or orbilogin.com can not be accesed. With direct wire connection to PC it get autoconfiguration IP as 169.254...... so that's why I have tried with manual IP 192.168......
