DKLEM
Jun 20, 2020Follower
Orbi Router compatibility RB550 & RBR40
Is Orbi Router RB550 & RBR40 compatiable to sync? Thank you!
CrimpOn
Jun 20, 2020Guru - Experienced User
DKLEM wrote:Is Orbi Router RB550 & RBR40 compatiable to sync? Thank you!
Since there is no Netgear product numbered RB550, my guess is that this product is actually an RBS50 (With my bifocals, an "S" often looks like a "5" to me. If so, then "yes" an RBS50 satellite is compatible with an RBR40 router. Should sync and work fine.
