martin-42
Jan 29, 2019Aspirant
Orbi router compatibility with Sky broadband
Hi,
I want to replace my existing router with an Orbi system to improve my Wifi but am conscious that for the router to work with Sky broadband it needs to support MER allowing it to use the ro...
Jan 29, 2019Guru - Experienced User
This is the Orbi Cable modem forum. So this unit already has a build in modem and router. Are you looking for just the Orbi router system?
I believe they do. I recommend you contact the ISP to see what is needed or required by the ISP to work with there system.
Also, be aware of modem/router combo units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- martin-42Feb 02, 2019Aspirant
Hi FURRYe38,
Thanks for the info, I didn't at first think about my requirement not needing a modem. Sky provide a BT Openworld fibre modem and a hub that I want to swap out. The issue is in order for any other device to get an IP via DHCP the device needs to support MER and the DHCP options to send a username and password.
I didn't see these details on any of the Orbi tech data I looked at.
I'll take a look and find the router forum.
Thanks
Martin
- FURRYe38Feb 02, 2019Guru - Experienced User
Ya, if you have Fiber as your ISP service, then the Cable Orbi will not work for you. Possible the non Cable modem Orbi system may work as a router replacement between the ISP fiber serivce and there router. Somerthing you'll need to ask the ISP about to see what they required and what can be used as a router on there system.
Good Luck.
