staciak
Apr 24, 2020Tutor
Orbi Router disconnecting
Hoping someone can help. This past week, the router has randomly been going offline and disconnecting wifi. I diconnect the router and reconnect when that happens and it then seems to be fine for a f...
Apr 24, 2020Guru - Experienced User
staciak wrote:Hoping someone can help. This past week, the router has randomly been going offline and disconnecting wifi. I diconnect the router and reconnect when that happens and it then seems to be fine for a few hours but then it happens again. I have children doing distance learning and every time this happens they get kicked out of class, I also work from home so this is very inconvenient. Does anyone know why this is happening and what I can do to fix it so it doesnt happen multiple times a day.
Thank you!
staciak
Apr 24, 2020Tutor
Hi -
Not sure I understand everything that you wrote below as I am not very tech-savvy..but i will try and answer as best i can ..
** The cable from Verizon Fios is plugged directly into my Orbi router
What is the size of your home? Sq Ft?What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
** The house is a hi-ranch with the router upstairs in the main room and one satellite downstairs. The room that the router is in is about 75 sq ft, this is the room that we use the computers in and they are within the 30 ft of the router.
** Have no idea what this is or where to find this info - can you explain further?
**yes - there are 4
**Have no idea what this all means or where to find it - can you advise?
- FURRYe38Apr 24, 2020Guru - Experienced User
staciak wrote:Hi -
** The cable from Verizon Fios is plugged directly into my Orbi routerIs there a model # on this FIOS unit?
Log into the RBR web page using a web browser.
Any Wifi Neighbors near by? If so, how many?**yes - there are 4
What channels are these nieghbors using. You'll need a wifi analyzer to check this.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).**Have no idea what this all means or where to find it - can you advise?
