funnystone64
Jul 28, 2019Aspirant
Orbi Router does not play nice when pointed to internal DNS
I have an RBR40 Orbi router (somehow this was not an option under the models dropdown list). Before version V2.3.5.30, I could change the DNS under Advanced > setup > internet setup to point to my in...
funnystone64
Thats a damn shame considering it was working before the firmware update. Really dissapointed in Netgear for breaking functionality like this.
Jul 28, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since the FW update?
What version had been loaded that was working? Might try reverting back to that...
- funnystone64Jul 28, 2019Aspirant
Haven't done a factory reset but I have done a hard reboot (unplug from power, wait, plug back in). I would revent back to old firmware if I knew how to but even if I did I would rather not becasue I am sure I would be missing out on some security patches for the router itself.
- FURRYe38Jul 28, 2019Guru - Experienced User
Power cycle is not enough. I would factory reset and setup from scratch and see if the problem still appears. It it was working in prior FW and is not now,even after the reset, then you should file a support ticket and information NG about this:
