dirceuguerra
Jun 18, 2020Aspirant
Orbi router does not recognize satellites connected to the switch
good morning everyone! I have encountered an annoying problem that has been taking time and I honestly don't know what to do. I've been trying to install a switch (dlink DGS 1008A) for two days on my ...
- Jun 18, 2020Then the new switch arrived (a TP-Link model) and ... it worked! Apparently the problem was the switch! Thank you all guys!
Jun 18, 2020Guru - Experienced User
how it it connected?
it should go:
gateway----->wan port on orbi router------>lan port on router to switch------>satellites.
dirceuguerra
Hi!
It is connected like this:
ISP Modem -----> Orbi internet port (Orbi is in router mode) -----> LAN port on Orbi router to LAN port on switch -----> Orbi Satellite connected at switch's LAN
- plemansJun 18, 2020Guru - Experienced User
what firmware is on the router and on the satellites?
Have you tried a different switch?
- dirceuguerraJun 18, 2020Aspirant
They all are using the latest firmware (V2.5.1.16)
I bought a new switch and it should probably arrive today. But a behavior that I found strange is that if I connect the switch to a free port on some satellite, everything works normally. The problem is when I connect a satellite directly to the switch.
- plemansJun 18, 2020Guru - Experienced UserI've heard of some of the "green" switches having issues. I've never had an issue and have 2 of them on my network.
- FURRYe38Jun 18, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
- dirceuguerraJun 18, 2020AspirantThen the new switch arrived (a TP-Link model) and ... it worked! Apparently the problem was the switch! Thank you all guys!
Glad to hear you got it working!
If you mark it as solved it can help the next person with that issue
