RQM
Aug 24, 2020Aspirant
Orbi router doesn't connect
My Orbi RK50 worked fine for ten months. Yesterday I had to reset the Spectrum cable modem for a smart thermostat problem. After rebooting, the Orbi system would not work. The router's top ring just ...
RQM
How do I check the firmware edition when I can't connect to the network?
Aug 24, 2020Guru - Experienced User
Can you use a wired PC connected to the RBR or a wireless PC or latop to connect to the RBRs default SSID name and PW?
There is a sticker under the RBR with default SSID name and PW info
