Las1234
Jan 17, 2021Aspirant
Orbi Router Drops devices
My Orbi is only connected to Verizon Fios ONT modem... (I only stream so I only subscribe to Internet) Is this why my Obrien continues to drop preset devices??
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
