havocdr
Jun 26, 2020Aspirant
Orbi router ethernet backhaul with both WAN and LAN ports used, is it a good setup?
Hello all, I setup my satelites using ethernet backhaul and I learnt from the other postings that both of the router's LAN and WAN ports can be used for the following reasons: 1. LAN PORT: I...
havocdr
BTW, my Oribi router is in AP mode.
- CrimpOnJun 26, 2020Guru - Experienced User
What this sounds like is the router feeds a switch and everything is connected to the switch (other devices, Orbi router, Orbi satellites).
The traditional way to configure an Orbi system is to connect the Orbi directly to the primary router and then connect the switch to the Orbi.
When configured as a router, Yes, the WAN and LAN ports have different IP addresses. That is because the Orbi router creates an independent IP subnet for everything that it will be assigning IP addresses to. In AP mode, all IP addresses are assigned by the primary router, so the Orbi router has only one IP address.
As long as your system is "working", the unusual wiring pattern should have no impact on service life.
