havocdr
Jun 26, 2020Aspirant
Orbi router ethernet backhaul with both WAN and LAN ports used, is it a good setup?
Hello all, I setup my satelites using ethernet backhaul and I learnt from the other postings that both of the router's LAN and WAN ports can be used for the following reasons: 1. LAN PORT: I...
Jun 26, 2020Guru - Experienced User
No, it's not recommended to use both ports. When in AP mode, the WAN port is connected to the upstream main host router. The other LAN ports on the RBR can be connected to other wired devices or LAN switches with RBS connected to the LAN ports or LAN switches behind the RBR:
havocdr wrote:Hello all,
1. LAN PORT: In order to enable ethernet backhaul with the satelites, the router's LAN port needs to be connect to the switch (one of the configuration option).
2. WAN PORT: If this port is not used, the router will show magenta LED ring and it won't go off. So I plug in another active ethernet cable from the switch used by the LAN PORT.
With the above router configuration, the router is no longer shown any light (Perfect) and the satalite connection type (as shown on the Orbi router's admin web page) is WIRED (Perfect).
Is the above router configuration a correct setup?
Would the Orbi router's life become shortened with this configuration?
How come the WAN and LAN ports did not get seperate IP addresses? (I have a router which I manage the ip addresses.)
Thank you for your time.
