Josh_hutter
Apr 17, 2020Aspirant
Orbi router extension
So my family has a orbi home system and one router extension. I recently got a pc and need to hardwire it with a Ethernet but my pc isn’t close to the router. And the extension doesn’t have Ethernet p...
Apr 18, 2020Guru - Experienced User
the RBS20, rbs40, rbs50, rbs40v all have ethernet ports.
which version of orbi system do you have?
- Josh_hutterApr 18, 2020AspirantOrbi WiFi system AC2200
- plemansApr 18, 2020Guru - Experienced User
the RBK50 system's satellites should be RBS50's and have ethernet ports.
What "extension" are you talking about?
- Josh_hutterApr 18, 2020AspirantSo our orbi router is actually a RBR20
