Josh_hutter
Apr 17, 2020Aspirant
Orbi router extension
So my family has a orbi home system and one router extension. I recently got a pc and need to hardwire it with a Ethernet but my pc isn’t close to the router. And the extension doesn’t have Ethernet p...
Josh_hutter
Apr 18, 2020Aspirant
Orbi WiFi system AC2200
Apr 18, 2020Guru - Experienced User
the RBK50 system's satellites should be RBS50's and have ethernet ports.
What "extension" are you talking about?
- Josh_hutterApr 18, 2020AspirantSo our orbi router is actually a RBR20
- plemansApr 18, 2020Guru - Experienced User
The router itself is an rbr20. What satellites do you have? Do you have any satellites with it or just the router?
If its just the router, any of the satellites I listed prior would work and have ethernet ports.
