Josh_hutter
Apr 17, 2020Aspirant
Orbi router extension
So my family has a orbi home system and one router extension. I recently got a pc and need to hardwire it with a Ethernet but my pc isn’t close to the router. And the extension doesn’t have Ethernet p...
Apr 20, 2020Guru - Experienced User
Also if more LAN Ports are needed, one can always add on a external LAN switch behing the RBR or RBS for additonal LAN ports.
Josh_hutter wrote:
So my family has a orbi home system and one router extension. I recently got a pc and need to hardwire it with a Ethernet but my pc isn’t close to the router. And the extension doesn’t have Ethernet ports. Is there a orbi product that is an extension to the home orbi that also has Ethernet ports?
