cuzanet
Aug 22, 2016Aspirant
Orbi Router Firmware RBR50
What kind of firmware does the Orbi router use. Is it DD-WRT, or is it proprietary? If proprietary what are the configuration options for the user?
peteytesting
Sep 26, 2016Hero
to be honest with you its clear you have more specific needs of your router than what the orbi is ever going to give you and your expectations will never be fully met by the orbi system alone , it will however work fine as ap/sat if you allow your gateway to do everything else , orbi isnt designed for the likes of your or me or enthusiased or geeks , its aimed at the set and forget market , adding more complexity will only exassibate many unresolved issues and add to the list , some of the stuff may become available in the future but lets wait and get the basics working first
Flash008
Sep 26, 2016Luminary
Thank You,
I felt this may be the response from Netgear. In my heart I knew when I purchased the Orbi I would have the typical Netgear experience of a very limited software design.
However, I do disagree that my needs are too much on the “geek” side. Netgear competition does not agree. ASUS, Dlink/Cisco and others seem to agree with users such as myself. They do not require me to sacrifice “everything” to gain “one thing”.
I feel if Netgear will not allow similar competing product features offered by ASUS, DLink/Cisco, etc. Then the only option would be to return the Orbi, wait for ASUS to deliver to market a Orbi alternative. I am sure they will use the same software base they use on existing products.
If ASUS does this, I think I can safely say that I will have an Orbi-Like-device in my home, without sacrificing the features I have had with Netgear competition.
What Netgear did with Orbi is wonderful and I am happy to see the Orbi. But I think we all know Orbi will not be the only product with a well-engineered Mesh setup with 802.11ac backhaul.
It saddens me that Netgear still feels they must strip their products of very desired features found on the completion, knowing the Orbi is only doing something that ASUS and others most likely have in their product roadmaps and their engineers are working on it currently.
- WPS should not be forced! It is very insecure. Countless documents from credited security firms supporting this comment can be found with a simple Google search.
- Guest Network is found on all network Router/WAP devices today. LOL. Even cheap ISP cable/DSL modem/WAPs offer guest network setup.
- Ability to see devices link speeds of connected devices. Very common today.
- Ability to change and set IPs, DNS, etc are found on every cheap and premium router/WAP sold on market today.
You can clearly see my point. 90 percent of every feature I listed in my post can be found on 90 percent of all competing products today. So how can Netgear say these features are for “Geeks’ only…???
- peteytestingSep 26, 2016Hero
please dont mis quote me , i didnt say those features where for geeks only but they are advanced features that the orbi team felt not needed in a set and forget type device such as the orbi adding more complexity will also complicate the build and design , i know thats not what you wanted to hear and as i said i think the orbi will never give you what you want esp in the next 3 days and its prob best you return it
i can however tell you at this time asus have no plans for such a device or aimed at this market in th near future
if you want something with capabilities look at the ubiquiti amplifi
