cuzanet
Aug 22, 2016Aspirant
Orbi Router Firmware RBR50
What kind of firmware does the Orbi router use. Is it DD-WRT, or is it proprietary? If proprietary what are the configuration options for the user?
toddcarothers
Jun 21, 2017Tutor
How do you join the beta?
DarrenM
Jun 22, 2017Sr. NETGEAR Moderator
Hello toddcarothers
Send me a Pm with your name, email, and phone number and our support team will contact you with the beta firmware. Also can you tell me what devices you are seeing disconnects on? This beta is only for RBK50 units.
DarrenM
