greenpeace's avatar
greenpeace
Orbi router frequently lost internet connection in IP passthrough mode
I followed this post from AT&T forum to set up its modem (Arris BGW210) to do IP passthough to my Orbi router:
https://forums.att.com/t5/AT-T-Internet-Equipment/Strict-NAT-Bridge-Mode-What-is-IP-Passthrough-Can-I-enable-on-my/td-p/5296974
It appeared to work at first. But later I found that the router lost Internet connection a few times a day. Everytime it was able to recover the connection in a minute or two. But it was really annoying. At the same time, the AT&T gateway seems to be functioning well as other devices directly connected to it worked well.
The problem went away if I set the Orbi router in AP mode. But I really like to keep the router mode to use the Circle parental control.
Any ideas?
Thanks.
  • CrimpOn's avatar
    CrimpOn
    Well, this is less "passthrough" than I would call "DMZ".  The Arris router and all of its telephone, television, and other functions remains intact.  The description of DHCP (particularly reducing the lease time to 2 minutes) is confusing.  This might explain why the Orbi "recovers within a couple of minutes" after losing internet.
    This is a great time for an Orbi customer who has AT&T to step in!!!
    p.s. What IP address does the Orbi show on the WAN (internet) side?
    i.e. a "public" IP address or a "private" IP address?
      • CrimpOn's avatar
        CrimpOn
        Great.  On the web interface, the Advanced Tab, Advanced Home screen, what does it show when you click on "Connection Status"?
        For example, my Orbi (on Spectrum) shows:
        Lease Obtained 1 day,  0 hours, 0 minutes
        Lease Expires  0 day, 19 hours, 4 minutes
