greenpeace
Jul 22, 2019Aspirant
Orbi router frequently lost internet connection in IP passthrough mode
I followed this post from AT&T forum to set up its modem (Arris BGW210) to do IP passthough to my Orbi router: https://forums.att.com/t5/AT-T-Internet-Equipment/Strict-NAT-Bridge-Mode-What-is-IP-...
- Jul 28, 2019
I decided to settle down on the AP mode for now. To get back the parental control function that is only available in router mode, I bought this stand-alone Circle device from Amazon and connected it with the ATT router:
https://www.amazon.com/gp/product/B019RC1EI8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It turns out to be working well and has more features than the one in the router.
greenpeace
Jul 23, 2019Aspirant
In AP mode it gets private IP address, which starts with 129.*
In router mode it gets public IP address, which starts with 75.*
Jul 23, 2019Guru - Experienced User
Try the Orbi in AP mode for a while and see if the problem still continues. Don't use IPPassthru for the RBR while in AP mode.
- greenpeaceJul 23, 2019Aspirant
I have already tried AP mode for a week and it worked well. But I lost parental control in this mode so it is still not ideal for me.
- FURRYe38Jul 23, 2019Guru - Experienced User
What FW version is the Orbi system currently loaded with?
- greenpeaceJul 24, 2019Aspirant
FURRYe38 wrote:What FW version is the Orbi system currently loaded with?
FIrmware version is V2.3.5.26
- FURRYe38Jul 24, 2019Guru - Experienced User
Has a power off of the ISP modem for 1 minute and back on and let it sync, then factory reset the RBR and setup from scratch? Walking thru the setup wizard. Keeping the passthru enabled on the modem for the RBR.
Ensure all wifi and uPnP on the modem is disabled.
Swap LAN cables between the modem and RBR. CAT6 is recommended.
How often does this loss of internet connect happen?
- Gudel2Jul 24, 2019Apprentice
Yes I have also battled this issue with the BGW210-700 in passthrough mode.
check firmware I think I am at 1.9.14.
I think it is something with the modem,because I have been using my old nvg510 and its working flawlessly. I am still trying to test with BGW 210 also.
Is there anyone in community who has this modem and has it set for passthrough have NOT had any disconnects? Please tell us how to resolve this.
- greenpeaceJul 28, 2019Aspirant
- FURRYe38Jul 28, 2019Guru - Experienced User
Glad it's working. Mark your thread as solved so others will know.
Enjoy. :smileywink:
greenpeace wrote:I decided to settle down on the AP mode for now. To get back the parental control function that is only available in router mode, I bought this stand-alone Circle device from Amazon and connected it with the ATT router:
