greenpeace
Jul 22, 2019Aspirant
Orbi router frequently lost internet connection in IP passthrough mode
I followed this post from AT&T forum to set up its modem (Arris BGW210) to do IP passthough to my Orbi router: https://forums.att.com/t5/AT-T-Internet-Equipment/Strict-NAT-Bridge-Mode-What-is-IP-...
- Jul 28, 2019
I decided to settle down on the AP mode for now. To get back the parental control function that is only available in router mode, I bought this stand-alone Circle device from Amazon and connected it with the ATT router:
https://www.amazon.com/gp/product/B019RC1EI8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It turns out to be working well and has more features than the one in the router.
greenpeace
Jul 23, 2019Aspirant
CrimpOn wrote:
greenpeace wrote:In AP mode it gets private IP address, which starts with 129.*
In router mode it gets public IP address, which starts with 75.*
I apologize. I have lost track of which device is which. When the Orbi is connected to the AT&T router, it should always receive the same IP address no matter whether the Orbi is in router or AP mode. The IP addressis coming from the AT&T router, either a public IP that it is "passing" to the Orbi, or a private IP that it has assigned. The IP that the Orbi receives should change when the AT&T router is put into a different mode.
By the way, "75" is not one of the generally recognized private IP spaces. https://en.wikipedia.org/wiki/Private_network
If the AT&T is "for real" passing the public IP to the Orbi, then the Orbi has to be in router mode, or it won't work. When the Orbi is in AP mode, then the AT&T must be handling the DHCP and giving the Orbi a private address.
Orbi gets a public IP address (75.*) when it is in router mode with IP passthrough, and gets private IP address (129.*) in AP mode without IP passthrough.
CrimpOn
Jul 23, 2019Guru - Experienced User
Thanks for the explanation. Got to hand it to AT&T not to use a recognized private IP space.
- greenpeaceJul 24, 2019Aspirant
CrimpOn wrote:
greenpeace wrote:
Orbi gets a public IP address (75.*) when it is in router mode with IP passthrough, and gets private IP address (129.*) in AP mode without IP passthrough.Thanks for the explanation. Got to hand it to AT&T not to use a recognized private IP space.
Checked again and the private IP the orbi gets in AP mode is 192.168.*. Sorry about the typo.
Any thoughts on why connections are lost with IP passthrough and router mode? You seem to suggest that it has something to do with DHCP lease?
