pcolsen
Jan 15, 2021Aspirant
Orbi router has 700Mbs from Modem, gives 2.0Mbs over WIFI
I have an RB50 router with firmware V2.5.2.4 connected to two satellites. My Orbi base station reports that it's getting 700Mbps download. My laptop is getting 2.1Mbs, and this has gone as low a...
Jan 16, 2021Guru - Experienced User
What speed do you get with connecting the laptops ethernet connection to the back of the RBR?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
pcolsen wrote:I have an RB50 router with firmware V2.5.2.4 connected to two satellites.
My Orbi base station reports that it's getting 700Mbps download. My laptop is getting 2.1Mbs, and this has gone as low as 1.0Mbs on WIFI. I have a physical connection through a pair of TP-Link Gigabit Powerline modems that provides about 7 Mbps.
I had this performace earlier. Since then I have rebooted the router several times and done one factory reset. The modem did increase speed immediately after the factory reset, but both WIFI and ethernet performacne had returned to the low speeds above.
I am serving two laptops, three printers, and some Amazon Echo devices. I have attached an older Netgear router to support 2.4Ghz smart devices such as bulbs. I have disconnected the attached modem and noticed no significant increase.
- FURRYe38Jan 16, 2021Guru - Experienced User
I recommend updating to v40 as well. Other user have posted problems with v4 FW:
