althea
Apr 21, 2017Guide
Orbi router in bridge mode over ethernet?
I am need of an Ethernet connection to a satellite in a separate house. Since a sattelite will not support an Ethernet connection, can a second Orbi router be used in bridge mode over Ethernet? Will...
- Apr 21, 2017
Yes, you could connect a 2nd RBR50 in access point mode at the end of an Ethernet cable in the 2nd house. I would strongly suggest from the 1st Orbi Router. It would have a separate wireless network from the other Orbi system, but that should be fine, being in a separate house and all. And if you need to add a satellite for that separate house, just add it as normal to the router/ap.
althea
Apr 22, 2017Guide
The other house is just a small one floor "cottage". It would have only one or three clients at time, usually and sometimes 802.11ac. I'm thinking I might get something advertised as just an access point like maybe this unless there are better recommendations:
https://www.amazon.com/gp/aw/d/B01LFSDZCU/ref=mp_s_a_1_1?ie=UTF8&qid=1492884270&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=netgear+access+point+wired&dpPl=1&dpID=31VEBr8HqfL&ref=plSrch
I'm very grateful for the help!!
st_shaw
Apr 22, 2017Master
Your pick looks like a good choice. Orbi would be overkill and far more expensive than needed for a one-floor cottage.
