Sberry8921
Jul 21, 2018Follower
Orbi router interfering with cell signal
Hi, ever since we set up our Orbi wifi routers, our cell service in the house has been unusable. Today, I turned them off and the cell service went back up to 4G. Has anyone else had this issue, and i...
BCG_Matt
Aug 16, 2018Aspirant
I have the exact same problem. Was using a Verizon router and switched over to Orbi; cell phones went from full bars to 1 or less and multiple dropped calls.
Aug 16, 2018Guru - Experienced User
And if you turn OFF the Orbi system, what do you see?
I presume when you are testing this, that the phones are not wirelessly connected to the Orbi wifi at the time?
