ekstam1105
Aug 28, 2019Aspirant
Orbi router is loosing internet connection
I bought RBR50 few days ago and from day1 internet is disconnecting frequently. Firmware version is V2.3.5.30. Satelite is at 2nd florr and router is at 1st floor, which are 30 ft apart.My old router...
Aug 28, 2019Guru - Experienced User
I would factory reset the RBR and this time don't enable any Armor or Circle. There are know known issues with these apps causing problems over the FW issues. My RBK50 runs well on v30 FW.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Possible the system you got from Amazon if faulty from the get go, maybe need to replace the entire system.
ekstam1105 wrote:I bought RBR50 few days ago and from day1 internet is disconnecting frequently. Firmware version is V2.3.5.30. Satelite is at 2nd florr and router is at 1st floor, which are 30 ft apart.My old router from Verizon never lost connection. I have enabled Armor. Around 15 devices are connected either Router or Satelite.We work from home and frequent connection issues is irritating my wife. I bought the new router from Amazon and Netgear Tech support is saying that the router is manufactured in 2016 and refurbished. I have option to return, but want to try few more days.
Any idea why I am losing connection.
- Retired_MemberAug 29, 2019
FURRYe38 wrote:My RBK50 runs well on v30 FW.
If you do a search you'll note you are in the minority.
How does telling people your system works fine with v30 FW help them?
