ekstam1105
Aug 28, 2019Aspirant
Orbi router is loosing internet connection
I bought RBR50 few days ago and from day1 internet is disconnecting frequently. Firmware version is V2.3.5.30. Satelite is at 2nd florr and router is at 1st floor, which are 30 ft apart.My old router...
ekstam1105
It is not working from Day1. Intermittently connections are dropped. Eventhough Wifi bars are strong, internet is not working. It is updated to new firmware during initial setup
Aug 29, 2019Guru - Experienced User
Possible the system you got from Amazon if faulty from the get go if it hasn't been working well since "day 1", maybe need to replace the entire system.
- Retired_MemberAug 29, 2019
FURRYe38 wrote:Possible the system you got from Amazon if faulty from the get go if it hasn't been working well since "day 1", maybe need to replace the entire system.
ekstam1105 wrote:It is not working from Day1. Intermittently connections are dropped. Eventhough Wifi bars are strong, internet is not working. It is updated to new firmware during initial setup
Not necessaily. IF this is a new system, once setup, the NG server will push the most current (?) FW (V2.3.5.30) and there ya go....
