deereman75
May 26, 2020Aspirant
orbi router is staying magenta other two satelittes are green
rbk23 on the app shows the router is magenta and the other 2 satelites are green i have wifi and internet also it will not hook up to play station 4 for some reason
- May 26, 2020
it started working all of a sudden and was able to connect to playstion didnt really do anything
deereman75
firmware is V2.3.5.30 internet is bridge from another modem
May 26, 2020Guru - Experienced User
What happens if you turn OFF the modem and RBR for 1 minute, then power ON the modem first and let it sync then power ON the RBR.
Be sure to check the modems ISP service signal as well. If the RBR is connected to a bridged modem and the signal fails for any reason, the RBR may reflect this with the top ring appearing as PINK.
- deereman75May 26, 2020Aspirant
- FURRYe38May 26, 2020Guru - Experienced User
Possible ISP service issue. Something to have your ISP check out.
Good Luck.
