Typhoon3214
Mar 03, 2020Follower
Orbi Router issues while gaming
While gaming, playing fortnite specifically, I run into some issues in game when I ping is at 40-70 and when I do a Speedtest it says I have 15 ping while using Ethernet. Is there something wrong with...
CrimpOn
Mar 03, 2020Guru - Experienced User
Typhoon3214 wrote:
While gaming, playing fortnite specifically, I run into some issues in game when I ping is at 40-70 and when I do a Speedtest it says I have 15 ping while using Ethernet. Is there something wrong with my router and how could I fix it if possible?
With the gaming computer connected to Orbi with ethernet, there is little that can be done to reduce latency (ping, for example). A brief search did not turn up the maximum latency that will work with Fortnite, however I did find this link that claims internet gaming should functin with pings under 150ms: https://www.highspeedinternet.com/resources/how-much-speed-do-i-need-for-online-gaming
70ms is less than 1/10 of a second. Is your trigger finger faster than that?
