Typhoon3214
Mar 03, 2020Follower
Orbi Router issues while gaming
While gaming, playing fortnite specifically, I run into some issues in game when I ping is at 40-70 and when I do a Speedtest it says I have 15 ping while using Ethernet. Is there something wrong with...
Mar 04, 2020Guru - Experienced User
Are you gaming with a wireless or wired connection to the Orbi? Wired is preferred.
Typhoon3214 wrote:
While gaming, playing fortnite specifically, I run into some issues in game when I ping is at 40-70 and when I do a Speedtest it says I have 15 ping while using Ethernet. Is there something wrong with my router and how could I fix it if possible?
