Typhoon3214
Mar 03, 2020Follower
Orbi Router issues while gaming
While gaming, playing fortnite specifically, I run into some issues in game when I ping is at 40-70 and when I do a Speedtest it says I have 15 ping while using Ethernet. Is there something wrong with...
Mar 05, 2020Guru - Experienced User
Any progress on this?
Typhoon3214 wrote:
While gaming, playing fortnite specifically, I run into some issues in game when I ping is at 40-70 and when I do a Speedtest it says I have 15 ping while using Ethernet. Is there something wrong with my router and how could I fix it if possible?
joryszak
Apr 14, 2020Aspirant
I have 1gig internet from COX. It comes into my home to my NETGEAR CM1000 modem. From there it goes into my ORBI RBR50. I plug my ps4 direclty into the orbi with the LAN cable. I recieve the same packet loss and lag spikes periodically. I seem to also recieve these same lag spikes over the wifi on my other devices. I DO have 15 devices connected to the orbi and satellite - doorbell, themostat, roomba, google minis, rokus etc. The lag spikes are so bad I cant even play games online. HELP!
