Orbiuser1985
Feb 15, 2019Aspirant
Orbi router issues
My RBK 50 has started dropping the internet connection again which is something that has happened several times in the past. When it does, I normally resolve this by performing a hard reset of the ro...
Feb 15, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
IPv6
Orbiuser1985 wrote:
My RBK 50 has started dropping the internet connection again which is something that has happened several times in the past. When it does, I normally resolve this by performing a hard reset of the router and satelitte and set it up again.
This time however, my problem persists. The router continues to drop the internet connection and I dont know what to do. I've hard reset the router 3 times now while the satelitte is disconnected just to see if I could get the router to be stable. But it was without any success.
I am now reaching out to the community to hear if you have any final ideas.
I am running firmware V2.2.1.210
Orbiuser1985
- FURRYe38Feb 15, 2019Guru - Experienced User
All wireless radios on this gateway disabled and turned OFF>?
Orbiuser1985 wrote:
Its a genexis router:
https://genexis.eu/product/hybrid/
Ap mode
no wifi neighbours nearby
