Geebs21's avatar
Geebs21
Follower
Jan 23, 2020
Orbi router keeps going offline and rebooting
The orbi router keeps going offline and rebooting several times a day. I see this has happened before. I had no issues until the firmware was updated.
1 Reply
  • What Firmware is currently loaded?
    Power OFF the ISP modem and RBR for 30 seconds, then power back on the ISP modem and let it sync then power ON the RBR.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
