Zorching
Nov 01, 2020Aspirant
Orbi router loosing internet connection every 10 days or so
Hi, My RBK50 router worked fine until few months back. It is running firmware version: V2.5.2.4 The last couple of months the Orbi looses its internet connection after 10 days or so. I ha...
Nov 01, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Has a power off for 1 minute then back on been performed since last update with the modem and Orbi system?
Zorching
Hi,
the modem/router provided by the ISP is a ZTE H369A. It can not be set into bridge mode. This is an VDSL modem/router including VOIP. So there is no coax in play and my network cabling is just fine, the wired part of my network (not connected with the orbi) keeps on working. The ISP router is never DOWN, just the orbi.
And yes, both modem and orbi have been (factory) reset multiple times;
The issue is that the orbi (access point) stops working - no wifi functionality, unable to access the management menu and logs. After a power cycle everything comes back to normal, but there no log or whatsoever of what happened.
- FURRYe38Nov 02, 2020Guru - Experienced User
Looks like your modem has a built in router already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- ZorchingNov 02, 2020Aspirant
Hi,
thanks for all those suggestions but I have passed that phase.
I have now downgraded the firmware - let's see how the orbi holding next 2 weeks.
Leshen
What phase have you passed? Helps to have an idea of the state of your ISP modem and it's configuration you have it in. Again, having two routers on the same line can cause problems.
