Zorching
Nov 01, 2020Aspirant
Orbi router loosing internet connection every 10 days or so
Hi, My RBK50 router worked fine until few months back. It is running firmware version: V2.5.2.4 The last couple of months the Orbi looses its internet connection after 10 days or so. I ha...
Zorching
Hi,
the modem/router provided by the ISP is a ZTE H369A. It can not be set into bridge mode. This is an VDSL modem/router including VOIP. So there is no coax in play and my network cabling is just fine, the wired part of my network (not connected with the orbi) keeps on working. The ISP router is never DOWN, just the orbi.
And yes, both modem and orbi have been (factory) reset multiple times;
The issue is that the orbi (access point) stops working - no wifi functionality, unable to access the management menu and logs. After a power cycle everything comes back to normal, but there no log or whatsoever of what happened.
Nov 02, 2020Guru - Experienced User
Looks like your modem has a built in router already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
