I99
Oct 28, 2019Follower
Orbi Router NBN Dropouts
Hi, I'm hoping that someone will be able to help me. I recently purchased a new Orbi RBR50v2 system (the two pack, one router and one satellite). My current setup is the Orbi router plugs directl...
Oct 29, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Does both wired and wireless connections fail during this dropout?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
